3.8L engine. Misfifing on above mentioned cylinders. Replaced Coil-Pack, Plugs and Wires, 2 Fuel Injectors and ran some water through the vaccuum system to create steam to help clean out any build-ups. All to no avail.
The following tests were performed and passed:
Compression
Fuel Pressure
Spark
My next guess is the ECM, but AutoZone told me that there is an Ignition Control Module that might be the cause, but I have think they are confused, because it's not located anywhere on my vehicle that I can find.
Thank you for your time and consideration in this matter.
Sincerely, Doug
SPONSORED LINKS
Sunday, June 29th, 2008 AT 7:48 PM
