1996 Ford Windstar chugging at idle speed mostly
MIKESKIING789
  • 1996 FORD WINDSTAR
  • 6 CYL
  • 180,000 MILES
New wires, plugs, fuel pump, injectors, fuel filter, air filter, upper intake gaskets, cleaned mass air flow sensor, cleaned intake, oil in intake tube and intake and van chugs slightly, tried spraying intake cleaner around all could think of to check for crack upper intake or vacuum leaks, none, When apply small vacuum to egr seems to make a difference on engine rpm so I think it is working properly, not positive about fuel regulator or how I can test. I don't think that catalytics are blocked because I seem to have good power. Seems like chug mostly at idle speed and most noticeable when in drive. Hear popping sound - sputter like. Pressure out back of exhaust is puffing, popping. Any tips, also cleaned and replaced one o2 sensor that looked like could have been damaged. Any tips?
Saturday, July 17th, 2010 AT 2:52 PM
LOCOESKIMO
I have that same issue with my van same mileage, except I have not replaced anything. I was wondering if it was an issue with cooling system. My van started chugging after I had full cooling flush after about 120 miles of use. I think there was some kind of clog that broke loose and then chugging. Also it started to overheat within 5 mins. Oil is black. Coolant level low by gallon, refilled. Van also has the rear heater and controls for rear passengers.
Tuesday, May 10th, 2011 AT 1:55 AM
