How do i correct exhaust fumes coming inside the vehicle when i am idle, but have the a/c or heater or vent turned on?
May 4, 2008 at 2:14 PM
BMRFIXIT
✓Experienced Mechanic
you have to check and fix any exhaust leak
check for any oil or coolant leaks and fix
when you use the ac it draws air from under the hood
fix what ever leaks you have that should take care of your issue
