1996 Ford Windstar Fuel System
134,000 MILES • 6 CYL • FWD • AUTOMATIC
DCHAVEZ
It died on me while I was turning the corner and then started right back up and took me to work. After work I tried to start it and it wasn't getting any fuel in the lines. I replaced fuel pump but still no fuel pressure? Still not getting any fuel through the fuel lines. My fuses aren't marked under the hood or in the van. Any ideas of what else might be wrong?
May 8, 2010 at 12:00 PM
  • 75,988 POSTS
Do you hear the fuel pump come On? If so check the fuel pressure with a guage if not check and test the inertia switch and fuel pump relay-
May 8, 2010 at 12:02 PM
