1996 Ford Windstar DTC Code P0743
124,000 MILES • 6 CYL • FWD • AUTOMATIC
HKYNKIM
My car is Windstar 96, and it has DTC code P0743 with Flashing OD(OverDrive) light.
How can I fix those problems?
Oct 4, 2008 at 11:45 AM
2CARPRO JACK
  • 11,533 POSTS
That is the code for a "torque converter clutch solenoid" your best bet is to have a trans shop look at it so they can verify the integrity of the wiring/circuit as well
Oct 5, 2008 at 1:25 AM
HKYNKIM
Thank you very much.
Before going to a tras shop, is there any wat to check the touble places,for example, continuity of lines, whereabout etc? I am a novie being interested in electric circuit diagrams. Can you recommend any wiring diagram to refer?
Any suggestion is welcome. Thanks.
hkynkim
Oct 5, 2008 at 2:14 AM
2CARPRO JACK
  • 11,533 POSTS
Yes, go here
https://www.2carpros.com/articles/mitchell1eautorepair-car-repair-manuals
Same software shops use, in "transmission" you should find complete wiring diagrams for your vehicles trans and controller circuit
Oct 6, 2008 at 12:45 AM
