1995 Ford Windstar wont start
183,000 MILES • 6 CYL • FWD • AUTOMATIC
DHASKINS
  • 6 POSTS
i have a 95 windstar, that wont start. i changed the fuel pump,filter,and plugs. i tested all injectors and they all read at 15. still wont start. it turned over for me one time and i let it run for about 20 mins took it for a drive it ran sluggish, i wasnt getting anything out of the the gas petal when i pressed on it. when i put it in park it runs smooth, and when i cut it off i have to use starter fliud and maybe it will start. help please i cant think of anything
Jul 23, 2008 at 4:04 PM
  • 75,988 POSTS
have a 95 windstar, that wont start -do below and comeback and tell me what happened
Get a carb cleaner and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel problem, check the fuel pressure to rule out the fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil,distributor pick-up coil, ignition control module, cam and crank sensors-
If both fuel and spark is present-check the valve and ignition timing, this will lead you to problems with compression and valves opening and closing at the wrong time
Jul 23, 2008 at 4:55 PM
