1995 Ford Windstar Vehicle Speed Sensor (VSS)
130,000 MILES • 6 CYL • 2WD • AUTOMATIC
A HOMSEY
Hi!
I cannot use the Haynes manual prescribed method to access the speed sensor. Is there anyother way to get to this part to replace.
I tried to go top down after removing cowl.
Please help. Thanks!!
Feb 18, 2010 at 2:03 AM
2CARPRO JACK
  • 11,533 POSTS
There is no easy way to do that sensor.If I remember correctly I have done a combo of top and bottom to access it.Try going in through the body on the side, there may be enough room there to access it, you will have to remove the heat shield.
Feb 19, 2010 at 12:19 AM
