Hi Dan,
It would help if you can get codes pulled. It could be the pump, shift seleniods, internal failure, there is so many possibilities.
You can also check the tranny fluid pressure, you will need a pressure test.
SPONSORED LINKS
Tuesday, March 17th, 2009 AT 5:12 PM
