Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Windstar
General
1995 Ford Windstar Replacing Bulbs
1995 FORD WINDSTAR
210,000 MILES • 6 CYL • 2WD • AUTOMATIC
BUZWON
MEMBER
How do I access the burned out backup and directional bulbs?
Aug 15, 2010 at 12:47 PM
BLUELIGHTNIN6
Experienced Mechanic
After removing the attaching screws, carefully separate the tail light lens from its mounting
Twist the light bulb socket 1/4 turn, then withdraw the bulb and socket assembly
Pull the light bulb straight from the socket This marker bulb lens is attached with two Torx head screws
Aug 15, 2010 at 5:24 PM
Add image or video
Ask a new question
Engine won't start
Check engine light
