1995 Ford Windstar ODB Code p1407
69,000 MILES • 6 CYL • 2WD • AUTOMATIC
DAYMIKE
I get a check engine light and when i check the ODB Codes I see p1407. This is a manufacturer reserved emmissions code. When I look it up on line at Actron I get a "No Code Found". Do you know what this code is or where I can look it up?
Thanks
Sep 10, 2008 at 8:56 AM
DOCFIXIT
  • 18,828 POSTS
Hi daymike
P1407
Egr valve no flow plunger stuck shut. See if vacuum is at EGR if it doesnot lift remove see if maybe passage way clogged.
Thanks for donation
Sep 10, 2008 at 9:11 AM
