Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Windstar
Engine
Crankshaft
Sensor
Is the CrankShaft Sensor the cause of a crank no start issue?
1995 FORD WINDSTAR
242,000 MILES • 6 CYL • AWD • AUTOMATIC
SOUTHERNSTYLE87
MEMBER
Does a crank shaft sensor have anything to do with my van turning over but not starting?
Oct 3, 2010 at 3:21 AM
Experienced Mechanic
Short answer is yes it does. The starter will turn the engine over but the ECM needs to know engine position in order to fire the plugs and injectors.
Here are a couple guides that will help with more info on this:
Below is the process from the manual that will give the detail needed in order to replace it if needed.
Please let us know if you have other questions. Thanks
Images (Click to enlarge)
Jul 5, 2021 at 12:13 PM
Add image or video
Ask a new question
Engine won't start
Check engine light
