1992 Ford Club Van odometer Died
What to check next
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
Use the actual vehicle wiring and service information to identify the speed-signal path and test where the signal is lost before replacing another sensor.
Guidance references and applicability
Source: This question and its visible discussion. The roadmap distinguishes the original owner's reports from other participants' experiences; proposed follow-up is editorial guidance, not a confirmed diagnosis.
Discussion summary
A 1992 Ford Club Van developed poor shifting when its speedometer and odometer stopped working. The owner could not locate a transmission speed sensor and later replaced the rear-axle ABS sensor without improvement.
Reported outcome: The rear-axle sensor replacement did not resolve the complaint; no later repair was reported.
The discussion did not establish the correct sensor arrangement or identify a failed instrument cluster or transmission.
