Ford Truck ignition
FORD TRUCK
NOELLYNN
Ford Truck
when I turn my key off the truck still runs, if I take the key out it still runs. I think it may be the ignition switch if so is it something I can repair myself??? appreciate your help. Thankyou
May 4, 2010 at 11:11 PM
  • 110,244 POSTS
The switch is located on the lower section of the steering column. It is a bolt on part, so you should be okay replacing it.
Oct 25, 2010 at 12:35 AM
