2006 Ford Truck Poor running
104,000 MILES • V8 • 2WD • AUTOMATIC
SMATTACE
After warming up when you come to a stop the RPM's drop very low and it sounds like a rod is going to come out then I press on the gas to raise the RPM's and it smooths out again. It does not do this all the time. Any suggestions?
Jul 5, 2010 at 12:19 PM
  • 75,988 POSTS
Clean out the idle air contdrol valve and EGR valve and test the throttle position and mass airflow sensors.
Jul 5, 2010 at 1:21 PM
