Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Truck
Engine
Camshaft
Camshaft Sensor
Location
2005 Ford Truck cam position sensor location
2005 FORD TRUCK
136,061 MILES • V8 • 2WD • AUTOMATIC
BUDDYG3205
MEMBER
where is the cam position sensor located on F550 with 6.0 L
May 12, 2009 at 4:17 AM
DOCFIXIT
Experienced Mechanic
Hi
Located left cylinder headjust below valve cover
Thanks for donate
May 12, 2009 at 4:55 AM
JDL
driver-side, downlow, toward the front of engine. You could also check the wiring colors at the connector, compare to wiring diagram, to make sure.
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine misfire
