2004 Ford Truck 2004 ford f-150 wont shift out of park
2004 FORD TRUCK
DENNIS72
Transmission problem
2004 Ford Truck V8 Two Wheel Drive Automatic
Dec 6, 2008 at 5:11 PM
MIKE H R
  • 3,094 POSTS
It has a shift nterlock system which prevents the vehicle from shifint unless the brake pedal is pushed down. Do you her a click when you press on the brakes. If not check the fuses . The actuator is mounted on the steering colume.
Dec 16, 2008 at 7:41 PM
