2003 Ford Truck DASH PANEL AND GAUGES
90,000 MILES • V8 • 4WD • AUTOMATIC
LENUE
THE TRUCK SHUT OFF,DEAD BATTERY, PUT NEW BATTERY IN, NO GAUGES WORK AND NO CHARGING,CHECKED ALL CONNECTIONS,REPLACED ALTENATOR,STILL NO CHARGE OR DASH GAUGES WORK.
Dec 8, 2008 at 7:11 AM
MIKE H R
  • 3,094 POSTS
check to see if you are getting volage to the fuse panel, then check all the fuses.
Dec 16, 2008 at 12:14 PM
