2002 Ford Truck pinging
2002 FORD TRUCK
ARGA
Engine Mechanical problem
2002 Ford Truck 6 cyl Two Wheel Drive Automatic
I have a 2002 F150 with 140,000 mile at low speed there is a pinging sound that sound similar to when a vehilce is running hot there is no over heating other than it runs fine what can that be an how to correct -
Nov 20, 2008 at 10:37 PM
DAVE H
  • 13,384 POSTS
Acceleration Ping/Knock
Faulty EGR System...Check EGR Valve and Hoses
Poor Knock Sensor Signal....Test Knock Sensor/Circuit
Poor Baro Sensor Signal...Test Baro Sensor/Circuit
Improper Ignition Timing...Adjust Timing
Engine Overheating.....Check Cooling System
Poor Quality Fuel....Use Different Fuel
Carbon Build-Up....Decarbon Engine
Nov 20, 2008 at 10:51 PM
