2002 Ford Truck 2002 f-150 want start
27,064 MILES • 6 CYL • 2WD • AUTOMATIC
TURBOBUICK2003
went to start my truck and want start,it isnt getting fuel or fire please help thanks
Feb 7, 2009 at 3:46 AM
BILLYMAC
  • 2,204 POSTS
this could be a security problem if security is flashing.unlock pass door with key and then drivers door. only if security light is flashing. is the ignition key in good condition.{coded key} if not a prob with key or security. then check all fuses ..check relay center .make sure check eng light is on while the key is on. check solinoid connections on starter.check injector pulse .check inertia switch has not shut down.. good luck billymac
Feb 11, 2009 at 1:20 PM
