2001 Ford Truck noise
81,000 MILES • 6 CYL • 4WD • AUTOMATIC
TINA TWO
One of my wheels is making a mosquito sounding noise when I'm under way --it comes and goes and kind of sounds like a europeon emergency vehicle siren sometimes and otherwise like a buzzing mosquito. brakes are good. when I drove it last and it made the noise I hit a bump and it stopped but I'm not sure it won't come back -- could it be a wheel bearing or just some dirt caught in the wheel. If dirt in wheel will it go away on it's own or should I have the wheels removed and cleaned or what? Thanks for any help. Tina
Feb 21, 2010 at 1:33 PM
HMAC300
  • 48,601 POSTS
as you stated that you hit a bump and it stopped it may have been rust caught in the wheel or caliper and when you hit the bump it came loose. Otherwise have a pro look at it so he can properly diagnose it.
Mar 1, 2010 at 12:45 PM
