2001 Ford Truck fuel injectors
2001 FORD TRUCK
20,400 MILES • 6 CYL • 2WD • MANUAL
TLOWE1963
fuel injectors staying energized....truck will not run
Jun 20, 2010 at 10:11 AM
Check the fuel pressure if its within specs if okay and you're getting injection pulses-Look for an ignition spark if it has the engine should combust
Jun 20, 2010 at 10:24 AM
