2000 Ford Truck smell coolant in cab from vents
2000 FORD TRUCK
JIM.CRENSHAW
Heater problem
2000 Ford Truck V8 Two Wheel Drive Automatic 95k miles
A/C also blows hot. I also noticed a drip/leak dripping at the bottom of the firewall and slightly to the left of the supply and return lines of the heater but at the bottom. 5/8 hose aproxamate size. The compressor engages I felt the line its cold. but I was told the other day they did get frosty.
Oct 16, 2009 at 6:26 AM
Sounds like the heater core is leaking or the AC drain tube is backed-up
Oct 16, 2009 at 9:03 AM
