2000 Ford Truck check engine light and air bag light will n
2000 FORD TRUCK
238,000 MILES • 6 CYL • 2WD • AUTOMATIC
JDTJR1
when I start up the engine the check engine and air bag light will not come on. I had the code checked and there are no codes.
Mar 19, 2009 at 10:02 AM
BMRFIXIT
  • 19,053 POSTS
no codes no check engine light on
if engine running and check engine light is on ,you have code
air bag codes, need a scanner to get the codes OBDII reader will not get the codes for the air bags
Mar 19, 2009 at 10:28 AM
JDTJR1
when I start the truck all the lights are suppose to come on. They all come on except the check engine light and the passanger air bag light will not light up
Mar 19, 2009 at 2:25 PM
BMRFIXIT
  • 19,053 POSTS
did u had the truck serviced for any of these lights before coming on ?
again with key on engine off the lights should come on
check if not bulb out or was removed
very rare circuit or a wire
Mar 19, 2009 at 10:52 PM
