1999 Ford Truck WONT START
LUVS2MUD09
Engine Mechanical problem
1999 Ford Truck V8 Four Wheel Drive Automatic
F350 will not start without being plugged in no one can find what the problem is.
Jan 4, 2010 at 8:52 AM
  • 75,988 POSTS
Disregard plugging it in, something has to give-do below to determine if its fuel or spark issue.
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Jan 4, 2010 at 9:07 AM
