1999 Ford Truck Service Engine Soon light came on / engine
1999 FORD TRUCK
240,000 MILES • V8 • 4WD • AUTOMATIC
TOMMY WALDROP
I own a 1999 Ford F-250 XLT 7.3 L Diesel 4x4. The service engine soon light came on. I serviced fuel filter. Engine seems to be running on 6 cylinders. Idles rough,runs rough,hard to start. Any suggestions ? Thank you.
May 2, 2010 at 7:19 AM
HMAC300
  • 48,601 POSTS
when the service engine light comes on you need to get the code scanned to see what is causing the problem. It means that a sensor has gone bad or not working any longer.....
May 2, 2010 at 12:57 PM
