1999 Ford Truck F-250 DIESEL
1999 FORD TRUCK
150,000 MILES • V8 • 4WD • AUTOMATIC
DAN BOND
SOMETIMES WHEN COLD THE THRORLE WILL NOT RESPOND ITS LIKE THE MOTOR IS OFF NO CHANGE IN RPMS. AFTER A FEW PUMPS IT RUNS LIKE IT SHOULD.
Dec 3, 2008 at 12:13 PM
  • 31,937 POSTS
Hi there,
This will be a problem within the injection pump, don't attempt to check or re adjust any of the settings as you could do more damage, get the dealer or a fuel pump specialist to do the diagnostics on the pump.
Mark (mhpautos)
Dec 3, 2008 at 3:01 PM
