1998 Ford Truck oxegen sensor
136,000 MILES • V8 • 4WD • AUTOMATIC
JAMIE39
check engine light on ford dealer said bad oxygen
sensor performance seems fine but light stays on
need to know how to change sensor
Jan 7, 2009 at 12:13 AM
MOBILEOILANDMORE
  • 39 POSTS
oxygen sensors are located on the exhaust near the motor and should be removed via a oxygen sensor tool. most auto part stores allow you to use the tool for free providing you put down a deposit that will be refunded apon return.
Jan 7, 2009 at 11:43 AM
