1998 Ford Truck High idle and reving
1998 FORD TRUCK
98,000 MILES • 6 CYL • 4WD • MANUAL
HAZY
I have a 1998 Ford Ranger XLT 4x4 with a 3.0L eng. and a 5 speed manual trans. Sometimes it will rev up to 2500 to 3000 RPM when I push in the cluth pedal. I have installed IAC valve, new EGR valve and it only helped for a short time. will I have to install a new PCM. Please help me
cdhaze@msn.com
Sep 4, 2010 at 1:40 AM
BILLYMAC
  • 2,204 POSTS
no prob not go to ford get it reflashed
Sep 13, 2010 at 10:54 AM
MIKE H R
  • 3,094 POSTS
At times I have seen many vehicles do the same thing , sometimes there is a small buildup of carbon in the throttle body that makes it stick. try cleaning out the air intake to the throttle body with throttle body cleaner.
Sep 18, 2010 at 3:19 AM
HAZY
I iinstalled a tp sensor and that took care of the problem.
Thank you
cdhaze@msn.com
Sep 18, 2010 at 12:59 PM
MIKE H R
  • 3,094 POSTS
Had a high idle on my wifes 2005 f150, used throttle body cleaner and cleared it up. Only had one tp sensor hang up and that was on a firebird. I am glad you got the problem fixed. Mike
Sep 23, 2010 at 2:56 AM
