1998 Ford Truck
23,800 MILES • V8 • 4WD • AUTOMATIC
TUFFY5
my truck will not move forward when it is in drive. it works fine in reverse but nothing happens when it is in drive.
Dec 10, 2008 at 1:07 PM
MIKE H R
  • 3,094 POSTS
First check the mell of the fluid on the dipstic? Does it smell burnt. Check to make sure you have enough fluid. If that is ok. you might want to have it flushed and filter changed. furst to see if the filter is clogged. If it stil wont go then you might have internal problems.
Dec 16, 2008 at 11:57 AM
