1997 Ford Truck turn signals
EJON5
Electrical problem
1997 Ford Truck V8 Two Wheel Drive Automatic 150.00 miles
my turn signals do not work . They worked for a while, but then quit. Checked fuse, new switch,new flasher ,new relay,checked bulbs. Coul the wires be loose in the harness? I noticed when i changed the switch a wire was loose the plastic piece inside the harnes was broken . So i tried to rig it ,could other wires be loose also?
Nov 15, 2008 at 9:14 PM
MIKE H R
  • 3,094 POSTS
check for a loose ground,
Dec 16, 2008 at 12:18 PM
