1997 Ford Truck swaybar links
1997 FORD TRUCK
175,000 MILES • V8 • 2WD • AUTOMATIC
GREG5517
Why would the swaybar links come loose?
Bad ball joints?
Nov 16, 2009 at 8:21 AM
  • 31,937 POSTS
HI there,
This may be more the case that the rubbers have collapsed and give the appearance that they have come loose, they should be attached with nylock self locking nuts, if this is not the case they should be replaced as the bushes.
Mark (mhpautos)
Nov 16, 2009 at 8:37 AM
GREG5517
The rubbers are there and don't appear to be collapsed, the bolts that go through the rubbers and the washers have 1 inch slack, all the rubber bushing are good
Nov 16, 2009 at 10:31 AM
  • 31,937 POSTS
Hi there,
I will see if Mitchell 1 shows this set up in any detail and i will then post my thoughts on the matter.
mark (mhpautos)
Nov 16, 2009 at 12:45 PM
