Electrical problem
1996 Ford Truck 6 cyl Two Wheel Drive Automatic
THE VAN IS SHOWING A CODE 44 RIGHT FRONT SENSOR IF NOT REPAIRED CAN THERE BE AIR BAG DEPLOYMENT WITHOUT CRASH?
Monday, May 4th, 2009 AT 3:23 PM
DR LOOT
MECHANIC
You are in no danger, the air bag will not deploy, it looks like someone ran into you when you were parked of the grocery store or the mall, and have damaged the sensor, try taking it to your local parts store and have them reset the airbag with their scanner.
