1996 Ford Truck
BIG FORD
  • 1996 FORD TRUCK
  • 6 CYL
  • 4WD
  • MANUAL
  • 187,000 MILES
Could my fuel pressure regulator be out if there is gas in the oil and my exhaust smell like gas is burning really rich plus it won't start its like its flooded
Wednesday, January 28th, 2009 AT 9:00 AM
BILLYMAC
  • 2,204 POSTS
Hi yes reg could be bad remove vac hose from reg check for gas in this hose. But another thought have you checked for codes. Could be a map sensor or tps or egr several things can cause this. Do you have fuel pressure.I would get it scnned and this will give you a better idea about where this fuel is comeing from. Good luck billymac
Wednesday, February 11th, 2009 AT 9:32 PM
