1995 Ford Truck temperature gauge.
114,000 MILES • V8 • 2WD • AUTOMATIC
JEB RUSSELL
I recently purchased this truck and the temperature gauge never moves, almost like it is unplugged. I changed the temperature sending unit on the thermostat and checked the connection to no avail. any suggestions?
Feb 8, 2009 at 11:26 PM
BILLYMAC
  • 2,204 POSTS
hi yes you can disconnect wire from sender at the engine. with key on ground this wire ,,the temp guage should berry to hot. if not wire or guage is bad. another possible buy aftermarket temp guage.easy install very accurate inexpensive,. billymac
Feb 11, 2009 at 1:12 PM
