1995 Ford Truck FREEZE PLUG
1995 FORD TRUCK
18,900 MILES • 6 CYL • 2WD • AUTOMATIC
SELFMADE1
IS IT OK TO TAP AND OLD FREEZE INTO THE BLOCK AND PLACE IT WITH A NEW ONE,INSTEAD OF PULLING IT OUT
Nov 26, 2008 at 1:08 PM
IMPALASS
  • 3,112 POSTS
Hello
I would not. It could block the flow of coolant through the engine. It is just as easy to remove it. You can either tap one edge until that end goes in and it should rotate. The grab it from the other end.
Also, you can take a sharp awl and punch a hole through it and put in a angled tool to pry it out.
Nov 26, 2008 at 1:32 PM
