1995 Ford Truck clutch
15,000 MILES • V8 • 4WD • MANUAL
TNARWOLD
Just bought a used truck. Wasn't shifting that great. We bled the clutch line and now it engages way at the bottom. Could it be that we did not properly bleed it or that there's some other clutch adjustment?
Tom
Feb 16, 2010 at 6:53 AM
HMAC300
  • 48,601 POSTS
try gravity bleeding first before pressure and then rebleed the system once more. You could have something else wrong iwth it as well. Make sure after bleeding that the clutch master is full as that wil effect it as well. Also check for worn parts from the slave cylinder, like th rod, worn out
Feb 21, 2010 at 8:02 AM
