1994 Ford Truck How to change a heater coil in a 94 F-150
JERRYBARNES
  • 1994 FORD TRUCK
  • 6 CYL
  • 168 MILES
Need to find some help as soon as soon as possible to change my heater coil.
Thursday, November 27th, 2008 AT 1:07 PM
DAVE H
  • 13,384 POSTS
Not sure which truck you have this description is for F250
HEATER CORE
Drain cooling system. Disconnect heater hoses. Remove glove box for access. Remove RABS module mounting screws and move module aside. Remove 7 screws attaching heater access cover to plenum. Disconnect vacuum source. Leave vacuum harness attached to cover. Remove cover. Remove heater core from plenum. To install, reverse removal procedure.
https://www.2carpros.com/forum/automotive_pictures/266999_heat_1.jpg
Thursday, November 27th, 2008 AT 1:24 PM
JERRYBARNES
Thanks for the help, but it is a 94 F150
Thursday, November 27th, 2008 AT 3:32 PM
DAVE H
  • 13,384 POSTS
Exactly the same for the F150.
Thursday, November 27th, 2008 AT 4:17 PM
JERRYBARNES
300 cubic inch 6, would that still the same? Also it is a 1994.
Thursday, November 27th, 2008 AT 5:18 PM
DAVE H
  • 13,384 POSTS
The heater system is showing as standard across the board F150/F250/F350 all the same removal/installation system.
Thursday, November 27th, 2008 AT 5:27 PM
