1994 Ford Truck Engine Flooding
1994 FORD TRUCK
DENNYDEAN
Engine Performance problem
1994 Ford Truck V8 Four Wheel Drive Automatic 200K miles
I have a 1994 F250HD 4x4 supercab xl 5.8L EFI V-8 Engine with Electronic 4-speed auto transmission w/OD with 200K miles. The engine ran fine and I moved the vehicle about 50-feet, and shut it off, and haven't been able to start it since. I found that the inside 4 cylinders are flooding with gas to the point that the engine locks. I replaced the fuel injectors - didn't help. I replaced the Distributor - didn't help. Changed plugs, wires, rotor, fuel filter - didn't help. When I turn on the ignition, the fuel pump starts and never stops, and the engine floods with gas. What's up with this Ford truck?
Jun 9, 2009 at 4:25 PM
DR LOOT
  • CAR REPAIR CONTRIBUTOR
  • 2,311 POSTS
Then it is obvious that you have a bad fuel pump
Jun 19, 2009 at 7:05 PM
DENNYDEAN
The fuel pump is pumping gas... like crazy! Why do you suspect it's the fuel pump?
Jun 20, 2009 at 2:16 PM
DR LOOT
  • 2,311 POSTS
because you stated "the fuel pump starts and never stops" the fuel pump comes on for a few seconds to prime the system then shut down, if the fuel pump does not shut down, it will flood the vehicle, the only other thing now I can think of is you have a bad fuel regulator which is located on the injection rail powered by a vacuum.
Jun 20, 2009 at 8:36 PM
