1991 Ford Truck
1991 FORD TRUCK
RAIDERSPITCHER
Electrical problem
1991 Ford Truck V8 Four Wheel Drive Automatic
We replaced the fuel pump and now it will not work. The pump is getting power but it will not start when the ignition is switched on. Could this be a problem with the starting relay and if so where is the relay?
Nov 26, 2008 at 1:04 PM
  • 110,244 POSTS
Does the engine crank when you turn the key? Are you getting fuel pressure to the injectors?
Dec 12, 2008 at 5:46 AM
