1990 Ford Truck Oil pressure gage
100,000 MILES • V8 • 2WD • MANUAL
MIZYED
The oil pressure gage shows no readings when the engine is on. It shows low reading when the switch is off. What could be the problem? The engine sounds running fine with no overheat and everything else looks normal.
Jun 19, 2010 at 10:12 AM
MERLIN2021
  • 17,250 POSTS
Could be the sending unit needs to be replaced.
Jun 19, 2010 at 10:21 AM
