1989 Ford Truck Engine quit
17,000 MILES • V8 • 2WD • MANUAL
MICHAELHAIRY
F150 5.0 fuel injected. Stalled on the way to work. No hesitation like running out of gas. 3/4 tank of gas. Did not overheat. Turns over fine. Oil leavel and water levels fine. Will not start or even try to start. I had new fuel pumps put in and the fuel tanks cleaned and a new switch on tanks this summer. The front tank does not work anymore. And we do not switch tanks both have gas. Can ya help. I am going to see this afternoon if there is any spark.
Feb 12, 2009 at 6:16 AM
SHAGNASTY80
  • 7 POSTS
did you ever get the truck running or do you still need help diag?
Feb 15, 2009 at 8:26 AM
