1987 Ford Truck heater control switch
1987 FORD TRUCK
112,548 MILES • V8 • 4WD • AUTOMATIC
PETROSKIE
my heater control switch only works on the lowest setting nomatter what setting you move it to. I replaced the blower motor, thinking maybe somthing was wrong with it from advise from a backyard mechanic. could you please point me in the right direction on what to do next. thanks for your time.
Nov 8, 2008 at 3:42 AM
MIKE H R
  • 3,094 POSTS
Under the hood disconeect the heater motor connection. With a static light chec to see if there is a difernce in voltage when the switch it turned up or down. If no diference check the fan switch control under the dash.
Dec 16, 2008 at 12:36 PM
