1987 Ford Truck fuel injection
1987 FORD TRUCK
JIM1975
Engine Mechanical problem
1987 Ford Truck V8 Two Wheel Drive Manual
i am trying to find out what the injector should read when testing current that each sends when cranking the engine. my truck does get fire to plugs and does get fuel all the way to the fuel injection pressure regulator. my truck will start to start but quickly die.
May 4, 2009 at 7:54 AM
DR LOOT
  • 2,311 POSTS
I guarantee you if your truck is starting up You do not have any injector problems, why don't you tell me what the fuel pressure was when you check it
May 18, 2009 at 2:56 AM
