1987 Ford Truck camshaft
1987 FORD TRUCK
120,000 MILES • 6 CYL • 2WD • AUTOMATIC
SALDIVAR13
My cam gear is broken along with my distributor gear and I want to replace my cam, distributor, and oil pump and cam bearings do I need to completely rebuild my engine.
Feb 12, 2010 at 9:56 AM
HMAC300
  • 48,601 POSTS
you shouldn't have to change yur cam bearings unless they are bad or scored. You don't have to rebuildyour engine. The most you'll have to do is clean out the oil pan when you change the oil pump.. as well as the other things........
Feb 21, 2010 at 7:51 AM
