1978 Ford Truck losing power to coil on a 78 ford f 100
167,387 MILES • V8 • 2WD • AUTOMATIC
BEASTRSF
My truck is losing power to the coil and will not start. I tried running a power wire from the (+) termanal on the coil to the battery and that usually got it started but now that is not working. I tried putting in a new coil and it still will not start.m
Oct 18, 2009 at 4:49 PM
  • 75,988 POSTS
Doing that with the jumper wire means you have an open circuit to the ignition switch. Now won't start at all-start checking the coil, distributor pick coil and ignition module
Oct 18, 2009 at 11:08 PM
