1976 Ford Truck over charging
1976 FORD TRUCK
MR_JONES
  • 9 POSTS
Electrical problem
1976 Ford Truck V8 Two Wheel Drive Manual
my 1976 f100 has been burinig batterys up ive changed the external regulator and checked all grounds but its still overcharging im lost i dont know what else to do
Jan 18, 2009 at 10:22 AM
Disconnect the EVR and test the battery voltage while engine is iding is it still overcharging
Jan 18, 2009 at 10:28 AM
MR_JONES
  • 9 POSTS
[quote:9053cebfb9="mr_jones"]Electrical problem
my 1976 f100 has been burinig batterys up ive changed the external regulator and checked all grounds but its still overcharging im lost i dont know what else to do[/quote:9053cebfb9]
ok i found a new problem while checking what you told me i noticed that the red-green wire comming from the ignition switch was verry hot and it seems to go to the I on the alternator regulator all this happened while the regulator was un hooked and the battery was gurgleing do you have any sugestions????? the vehicle was running.
Jan 19, 2009 at 7:23 AM
Its still overcharging-inspect and test the wires that goes to the ignition switch and charge indicator from the alty for short and open wire
Jan 19, 2009 at 7:26 AM
MR_JONES
  • 9 POSTS
[quote:938ffef49f="rasmataz"]Its still overcharging-inspect and test the wires that goes to the ignition switch and charge indicator from the alty for short and open wire[/quote:938ffef49f]
i have a question can i change the alternator out for a alternator without a external charge regulator but with a internal regulator that way i can do away with a lot of wiring
Jan 29, 2009 at 6:19 AM
Have you tried replacing the regulator-To answer your Q-could be done if you wire it correctly
Jan 29, 2009 at 6:27 AM
MR_JONES
  • 9 POSTS
i changed the regulator ive changed every thing and Ive went thru all the wiring and it still overcharges
Jan 29, 2009 at 6:32 AM
Try running it w/o the regulator-Is it still overcharging if so you still have a wiring problem between the regulator and alternator
Jan 29, 2009 at 6:42 AM
MR_JONES
  • 9 POSTS
i have a stupid question if the truck is running and the hot cable is removed is it supposed to die??? with a alternator with a external regulator???
Jan 29, 2009 at 8:35 AM
Nothing is stupid unless its not asked-its suppose to keep running
Jan 29, 2009 at 8:50 AM
MR_JONES
  • 9 POSTS
does a ground wire go from the gharge regulator
Feb 25, 2009 at 8:19 AM
No there's no ground wire that goes to the charge indicator
Feb 25, 2009 at 9:26 AM
What's your problem -there's no ground circuit to charge indicator it comes from the ignition switch thru the indicator and back to the alternator for field excitation. Right now you're lost in the woods and you need my help that's why I responded not trying to be a ( bad word )
You got 4 wires going to the voltage regulator IASF there's no ground there the alternator housing provides the ground
Feb 25, 2009 at 10:40 AM
MR_JONES
  • 9 POSTS
ok thank you im sorry about getting mad im just fustrated about the charging problem i do need your help and thank you for all the help you have given me
Feb 26, 2009 at 5:21 AM
MR_JONES
  • 9 POSTS
i found that the voltage meter wasnt working i think it need to have volts to go thru to go back to the battery does it need to have volts to go thru to get back to charge the battery
Feb 26, 2009 at 8:41 AM
