1976 Ford Truck Heater core
1976 FORD TRUCK
THUNDEROFJ
Heater problem
1976 Ford Truck V8 Two Wheel Drive Automatic
I have a 76 f-100 with a/c. im trying to change the heater core but the panel under the dash is glued on. whats the best way to get to the heater core.
Feb 15, 2009 at 2:36 PM
SHAGNASTY80
  • 7 POSTS
Disconnect the battery ground cable.
Remove the air cleaner.
Drain the engine coolant below the level of the heater core.
Remove the heater hoses from the heater core.
Remove the screw fastening the A/C hose support bracket to the firewall.
The expansion valve is located on the right side of the evaporator core housing. Remove the insulating tape covering the valve.
Remove the two screws holding the plate over the opening that the A/C hoses exit the evaporator housing. Remove the plate and the seal.
Remove the glove box liner.
Separate the A/C duct from the register in the instrument panel and free the clip holding it to the plenum. Remove the duct from under the dash.
Remove the vacuum hose from the vacuum motor on the right hand side of the air box.
Remove the rear housing cover from the evaporator housing. The cover is retained by 4 nuts and one bolt. Disconnect the fresh air tube from the rear cover. After the cover is removed reinstall one nut to secure the evaporator housing to the firewall.
Gently remove the capillary tube from the evaporator core. Disconnect the wires from the icing sensor. Remove the plate the sensor is mounted to.
Remove the plenum by extracting the two screws above the transmission tunnel that hold the plenum to the dash.
Remove the screws securing the evaporator.
Pull the evaporator from the case and secure it above the case.
Remove the heater core.
Remove the heater air control door. There are no screws this is retained by a spring clip and snaps off.
Remove the arm that supports the air control door and the retainer that secures the pivot arm.
Remove the blower motor.
Transfer the blower wheel to the new motor.
Reverse the disassembly steps to assemble the heater A/C box.
Feb 15, 2009 at 4:15 PM
