1964 Ford Truck engine size plugs and points gap?
TONYNEAL
  • 37 POSTS
1964 Ford Truck Two Wheel Drive Automatic
Motor was changed and the only numbers I could find, 37 and 352, were on the block. I also located numbers on the manifold but dont know if it is original.
Q: Motor is supposed to be from a 65 or 67, how can
I find out exactly what year it is?
Q: I also need to know what the timming should be
set at?
Nov 3, 2010 at 2:50 AM
WRENCHTECH
  • 20,760 POSTS
352 cubic inch is the engine size. The point gap is .017" or 30 degrees of dwell and the plug gap is .035"
Nov 3, 2010 at 3:05 AM
