1975 Ford Torino Agressive rear swaying
141,000 MILES • V8 • 2WD • AUTOMATIC
MASWELL
When gradualy accelerating, no problem. When the car hits 75-8- mph the rear end sways/swings side to side. Let of the accelerator and i immediately stops.
Also, if I gun it to pass, it reacts the same way.
Any idea of what it is and reasonable cost to fix?
Jul 9, 2009 at 10:09 AM
HMAC300
  • 48,601 POSTS
check to see if your axle bolts are tight and the bushings are good shape for the rear end. Also if you have a sway bar make sure it is tight and shocks are in good shape. Also check to make sure your wheel lug nuts are tight. Or best bet let a pro look at it. he'll probbaly find out what the problem is.
Dec 17, 2009 at 11:27 AM
