1970 Ford Torino Carburetor
1970 FORD TORINO
99,000 MILES • V8 • 2WD • AUTOMATIC
RWAMES2
I have a 1970 Ford Torino and my problem is that the engine was sputtering when I would first accelerate like it was about to shut off.. So I took the carb of and rebuilt it, put it back on, and now when i start it up it is running rough and when i put it in drive it comes very close to dying. I have already adjusted the choke in everyway possible with no better result. What is wrong??
Sep 13, 2009 at 4:28 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Have you adjusted AF mix screws? checked for vacuum leaks? Stock ignition? points set timming on?
Hook up Vacuum gague adj screws to max. Vac in. and highest RPM
Let me know
Thanks for donate
Sep 13, 2009 at 7:17 AM
Could be float level set incorrectly,carb jets and adjustment of the mixture screws and curb idle speed if its not doing that before you overhaul it-
Sep 13, 2009 at 8:42 AM
